Motorola 2 way FRS radios clearance at OD tomorrow for 24.88
alchemist
Here's a heads up, there are some motorola 2-way radios going on clearance tomorrow at OD for 24.88, dont quite remember the sku, was 814-*** but thought you'd like to know.
bonedoctor
32
Anyone know how good these are compared to the Panasonic 325 series? Or compared to the 320 series?
serzone
324
Somebody needs to tell my local OD what a clearance is. The only crap they have are some really old software and toner cartridges, marked down about 10%. Wankers!
WantMoreDeals
110
[links deleted by AnandTech Moderator for member security]
I think its these. If they are then ITS GREAT !!!!
alchemist
if i knew more i'd tell you....hmmm seeing something print in passing and remembering it all while i'm trying to get info for somehting else. like i said i dont know the rest. just motorola talkabouts, blue and silver tomorrow. i went back tonite, and was going to get more info, but couldnt get more info....wanst supposed to be out till tomorrow
Cybordolphin
2,813
Does Staples still price match OD??
If it IS the talkabouts 250.... they will go quickly.
Thanks for the HU!:)
Scorpi0
336
I'm sorry but I saw Motorola fr50 for that price last week in my local OD store. And as far as I know rebate doesn't apply to fr50.
dogberry
162
WantMoreDeals - you might want to modify/remove those links
#IKE #AYBERRY
##31 4#TH AVE NW
OLYMPIA, WA
98502-####
USA
(360) 943-83##
Scorpi0
336
Good catch DogBerry :)
Mike- you should be more careful man! What if you had your CC info there? :(:(:(
AndrewR
Ok, bought two and will price guarantee them tomorrow. I'll let everyone know (assuming I make it back there, that is).
If anyone else goes, check the FR50, too, based on Scorpi0's post.
adinar
174
Any further word on this deal? Has anyone gone to OD to check out if this is true or not? Let the rest of us know! :)
--C
Bandito
148
Our local OD claims that the info is downloaded from Corporate at midnight. They are showing no clearance. I called two different stores.
One store did have them for 59.99 and the other store had them for 69.99.
When I talked to a manager I was told the other store may have a different price because they have one less local competitor in that particular area.
MontyBurns
2,836
This seems to always happen on things like this... not flaming hte original poster, but whenever people "hear" about a clearance, it rarely happens, and when it does it rarely applies across the country.
alchemist
to the winy little ahole who said i might be lying.....i got that said to me the last time i posted a deal at OD.....well F'you I should know, i work there. Yea i didnt know the sku....only the first half, I wasnt supposed to see it in the first place. well i bought them today. The motorla 280slk for 24.88 the UPC is 072375553705 and 072375553706 so you can all go to hell now
aolshove
29
Are these radios frequency compatible with the VTech radios that were on sale at Amazon a few days ago? Thanks!
Bandito
148
Could you please give us a sku number...my local OD said she couldn't look anything up by that UPC
alchemist
i dont know the sku offhand. i just have the reciept in my hand right now. and they lied to you by saying they can t lookup by the UPC....i do it all the time at work. If you havent figured it out, i work there
all the reciept prints out is the UPC, and i have two diff ones silver and magenta
072375553705
072375553706
they are compatable with all the 14 channel 38 subcode models by any manufacturer.
model is 280SLK
