Motor Trend Head 2 Head - Mazdaspeed 3 vs Focus ST
hans007
20,212
18
i am really impressed by the focus ST. maybe its not as fast straight line as the ms3, but its a really well built car. friend bought one, and i've sat in both it, the ms3 and the frs.
they are probably all fairly close in performance, but the focus ST is just the nicer car. even just sittign in it, it feels like an expensive car AND it drives well for $25k. best overall car in that class i think
Wingznut
16,968
Although I have driven none of the three... I'd be very shocked if I'd choose either of the FWD cars over a RWD FRS.
JCH13
4,981
66
Very cool, and seems quite fair.
Clearly explains why many MS3 owners add a significantly stiffer rear sway bar.
Vdubchaos
10,408
10
Ford is really doing very nice things lately. I would def take the ST over Mazdaspeed, but that's mostly due to styling. New MS3 is just hidious. That grin is just so ridicules.
I would however take the previous gen MS3 over the ST.....
JulesMaximus
74,544
924
Agreed. The ST is the car to have in this segment.
hans007
20,212
18
My friend choose the st over the FRS. Another friend has a FRS and another a brz. As an only car st is just a lot more practical. You can actually put stuff in it , real people can sit in the back etc. The st also tends to cost less. The brz interior and seats are nicer than the FRS but at that point its even more money
On a track its probably worse but in day to day he said its just easier to drive since it has more torque. The frs interior is also complete crap compared to the st. I'd put the FRS interior at Toyota yaris level terrible but car mags call this "basic and focused on driving". .
FRS is a better driving car for sure. But for most people I'd say its a worse car
Vdubchaos
10,408
10
Good post
Most people fail to keep these to completely seperate.....and end up learning the hard way.
Keep your "nice/special car" COMPLETELY separate from "Daily driver".
It's just SO much better that way ALL around.
vi edit
62,484
8,344
Would love to see how the next gen GTi stands up to these. Right now it's supposed to be 200 pounds lighter than the previous generation, and up 20HP and 50ft/lbs putting it right in line with these two cars. Not sure if the mechanical diff is making it stateside or not. Good time for hot hatches.
Vdubchaos
10,408
10
By that time Ford/Mazda will add more power as well.
VWs have a long history of being well underpowered. They are more balanced vs raw.
xSkyDrAx
7,706
Good post
Except for that it usually cost more money part.
SketchMaster
3,100
149
I got to test drive the ST and completely agree with the review, it's a hoot to drive WOT but I could cruise in it and be comfortable; all while getting decent MPG. I also loved the feel in the steering, I remember getting in a Cobalt SS-SC a few years back and instantly hating the car because of the completely numb steering.
Looking forward to see where Ford takes this platform.
cyclistca
2,885
11
I have tested both and I would take the Ford ST over the FRS for my daily drive. The FRS was fun but the back seat is a joke and the interior finish is not even close to the Ford.
Zap
22,377
:thumbsup:
Maybe I'm a product of my formative years, but to me a "hatchback" had 2 doors and a long, sloping rear window that opened up.
^^^ FWIW I had one that was almost identical to that in looks, other than being a darker red ("Canyon Red").
Seems like now a "hatchback" is a 4-door station wagon with a shorter butt.
Vdubchaos
10,408
10
In the long run, probably not. Keeping your "nice" car in the tip top shape is not only impossible but also costly.
Besides the fact that cars lose their value QUICK as you rack up miles....
So the answer is, not necessarily.
xSkyDrAx
7,706
Value wise having one car may depreciate faster than having 2 but in terms of actual money being spent it's still going to be cheaper/better value to have one car.
If you buy a new car that's a mix of both dd and weekend it's most likely going to be cheaper than if you bought 2 new cars with specific purposes (both new for sake of argument)
If you go the used route you're still in a similar situation. You can buy a better/less mileage car that's a mix of what you need versus splitting your budget and getting 2 but most likely higher mileage and potentially more issues cars that you can split your driving.
Vdubchaos
10,408
10
I tell you what. You drive your "special" car on daily basis and tell me how special it is 3-5 years down the road. If you have a daily and a special car for those special days, chances are you will have that car for a VERY VERY long time. You will also care for it lot more as it will not be exposed to daily tear and wear. I've been down this road and I've seen plenty of folks do it as well.
Cost wise, ok fine, let's say you are right. But you will NOT have that car for a VERY long time, neither will you care for it much 3-5 years into the ownership.
I won't even get into the TIME it takes to keep the daily clean (like that special car should be). I remember I used to wash my car every 3-4 days to keep it in tip top shape....which it was never in anyways.
Then there is the whole risk thing. When you drive daily you WILL have dings/paint scratches and your chances of accident rises significantly.
Find out for yourself. It's not for everyone, but I found that it's best to keep the 2 completely separate. I think it's just better that way ALL around.
PS. Climate might have a lot to do with it. I'm in northeast and noticed you are in Cali (better climate situation)
hans007
20,212
18
Good post
i agree with this generally, but the problem is not owning 2 cars for me other than having a place to park them.
so then you end up buying 1 car and trying to make the best of it. i guess for some people they get the better driving car, and others go for more practical.
like if i had 2 cars and say a house, i'd have no problem say buying a cheaper car like a honda fit, and say a miata as my impractical 2nd car
but i think if you only have 1 car, i think its just too hard to go way too far on the impractical side.
friend of mine keeps saying i should just buya cayman or something as my next car, and among other reasons i say it'll never happen (on top of being expensive, it just has too many drawbacks as an only car)
JulesMaximus
74,544
924
:thumbsup:
I had one that was identical to this.
Black '86 GT Convertible with grey interior. Those are the stock wheels. I bought it used with only 40k miles on it in 1990 after I moved to Los Angeles. I met my wife while I owned that car, cruised Hollywood and explored areas like Mulholland Dr. and Rancho Palos Verdes in that car. I have a lot of fond memories in that car despite its many shortcomings. It looked good, was reasonably fast, had that top down goodness and it was reliable.
phucheneh
7,306
I'm curious as to how either of those cars do against a price-competitive RWD or AWD car. Basically, WRX or FR-S/BR-Z, right? I don't know of anything else that can be had in the mid-20's.
Next thing up is probably a 370Z or Genesis V6. I'm guessing they'd stomp the FWD's on a bigger track, but it could be competitive at lower speeds. Could also throw a Mustang V6 into a track showdown. For the lulz.
Aharami
21,205
165
Price, mileage, interior, 6-speed. Really the only reason to get a WRX is all wheel drive. And it doesn't snow here.
Hopefully the next WRX will fix all that. I'm a hatch lover and this is a good time to be one!
edit: base WRX is like $1K more than than the ST and speed3. So price is pretty comparable
