Originally posted by: mugs
My sister thinks she has to use olive oil in her car, because it has a high performance engine. I tell her canola oil works fine in my Civic, so it should be fine for her car. Who is right?
Originally posted by: wanmichael
What kind of high performance car is it anyway?
I don't have a sister.Free bump. I use AMSOIL because it's the only synthetic 5W-20 I've been able to find.
Originally posted by: armatron
my motorcycle has a wet clutch... some SWEAR by the hype from motorcycle-specific oils..... is it actually better, or will ANY non-energy conserving oil work fine?
Sorry, not familiar with motorcycles at all. I don't want to provide incorrect advise that may result in damage to the motorcycle.
Make/Model of your SUV?
Driving Conditions?
Past Maintenance History?
What is your current interval with Syntec 5/50?
Amount of Mileage yearly?
Originally posted by: mdcrab
IF you use a synthetic motor oil should you change the oil filter twice as often as the oil?
If you change the oil every 10k mi, should you change the filter every 5k mi?
I have a new Honda Accord v-6 and am thinking about using Mobil 1. Manufacturer recommends 5w-30, but should I use 0w-20?
mdcrab
Driving Conditions?
1994 Nissan Pathfinder used for big load shopping and weekend trips to cabin under all kinds of conditions and weather - though very little freeway driving. Only putting about 5000 miles a year on it and oil is changed every 6 months.
Driving Conditions?
Once a year with Mobil 1 5W-30 and oversized Purolator filter should be fine. Any oil should be able to last 5,000 miles unless there is a mechanical problem. It'd be great if you could take it on a highway trip once in a while to burn off some fuel that may have accumulated in the oil because of the short trips. Consider getting it analyzed by Blackstone.
okay I have a nissan 200sx (1998) with 99k miles on it. I've ran mobil 1 10w30 for like 50k miles now... is it time to switch to the mobil 1 high milage synthetic?
It hasn't been driven hard nor easy granda-like. I've always changed the oil after 3k miles... even though I know I can wait 5k+ with the full syn.
Originally posted by: aic
I buy any major oil. shell, exxon, pennzoil, quaker, valvoline. I always use 5w-30 and I usually go 4-6 months and 3-5,000 miles. never used synthetic. My honda has 127,000 miles and a compression test came back good. oil is oil is what consumer reports said. I don't think they tested synthetic back then, years ago.
Originally posted by: OS
do either mobil 1 0w-20 or 5w-20 use viscosity improvers?
