- Dec 4, 2004
- 54
- 0
- 0
Building a computer for daughter and wanted to use Shuttle AN35N motherboard.
It was bought off ths website a couple of years ago and was in storage and had never been
used by me before now.
Troubleshooting
1. Overview of the problem
Motherboard will not POST!
___________________________________________________________________
2. Full description of the problem and symptoms
Need to swap out motherboards and first want to bench build to test.
Assembled Motherboard on workbench with just cpu/fan/video card/ram and
hooked up working psu (400w). Motherboard led lights until I push start button and
then it goes out and nothing happens. Fan on Cpu is working and video card
came out of another computer that was working.
Took motherboard to computer shop and they advised me it was a bad cpu but
I put it another motherboard and it posts fine.
_____________________________________________________________________-
3. Did it work normally at one time, or has the problem always existed?
First time motherboard used all other parts came from working computer.
_________________________________________________________________________
4. Is the problem consistent and repeatable, or entirely random, or semi-random?
Completely repeatable
__________________________________________________________________________
5. I already tried these steps:
Stripped down to MB/CPU/Video/Ram, same result, Removed memory to hear the
the beep code but nothing happens. Tried another power supply and still get nothing.
6. My software:
No hard drives installed yet.
7. My hardware
* System brand & model, if it?s a pre-built system such as a Dell, HP, Gateway, etc. If it?s not, fill in as much of the information below as you can.
* Shuttle AN35N Ultra
* AMD Athlon XP 1800 or 2000
* e-GeForce FX5200 128MB AGP
* (1) Crucial PC2700 512k
* Antec 350w
8. Other information that might be relevant
All parts have been checked on another motherboard and work fine.
Troubleshooting
6. My software:
7. My hardware
* Antec 350w
