- Jun 30, 2004
- 16,830
- 2,148
- 126
Here is page 1-32 of my ASUS Z170-WS motherboard manual:
I'm not sure, but I don't think I've ever worked with a motherboard in the EATX spec. This motherboard is an ATX motherboard in its size spec. It requires, in addition to the 24-pin EATXPWR connection plug, two 8-pin EATX12V connections with plugs sitting side by side, and a third EATX12V connection to a plug with six pins. No information in the manual explains any circumstance where one would not connect all of these plugs, so one assumes they all require connections to the PSU.
I have a Seasonic Prime Titanium TX-750 750W PSU, and I assume that it at least meets the ATX 2.0 specification because the spec is long-established and most PSUs comply with it and with later versions.
So, in addition to the cable and PSU ports for the 24-pin connector, I have two 12V 8-pin "CPU to PSU" cables, which will fill the bill for connecting EATX12V and EATX12V1 as shown on the mobo manual page. This leaves a need for a cable connecting the 6-pin EATX12V_1 plug to the PSU. The only cables available other than SATA and legacy 4-pin Molex connectors are the PCI-E-to-PSU cables. We always use these for graphics card power connections. They are capable of fitting an 8-pin plug on a PCIE device, but two of the pinouts are separable and are not used in graphics cards I've had, leaving the use of the main six-pin connector.
SHOULD I ASSUME that it is this type of PSU-to-PCIE cable intended to fit the third motherboard power plug (EATX12V_1)? I notice that all of the molded retainers of the pins fit the pattern or shapes of the corresponding pinouts on the motherboard plug, except one. On the left side of the motherboard plug's diagram, the middle pin-out is square, while the Seasonic PCIE cable has a rounded edge for the corresponding pin. Thus, the cable will still fit the motherboard plug. One might describe it this way: you can put a round peg in the square hole, but you cannot put a square peg in a round hole
I don't want to connect my Titanium PSU and high-end workstation motherboard in any way that will fail their functions or cause damage to either one.
I know this nit-picky concern might seem silly or trivial to some, but some people may have more experience with this type of workstation motherboard and its 12V connections, so someone would know for sure. That's better than my making educated guesses, with a lack of experience for this type of motherboard.
Thank you very much for your comments and guidance.
