motherboard temperature is TOO HIGH ?
funnyfenix
516
SiSoftware Sandra
System
Manufacturer : soyocomputer
Model : P4IPE
Version : 1.X
Serial Number : 00000000
System Chassis
Type : Desktop
Can be locked : No
Version : 1.X
Asset Tag : To Be Filled By O.E.M.
Boot-up State : Safe
Power State : Safe
Mainboard
MP Support : 1 CPU(s)
MPS Version : 1.40
Model : P4IPE
Version : 1.X
System BIOS : 62-0100-001131-00101111-122904-SPDALE
On-board Devices
To Be filled by O.E.M. : Video Adapter (Enabled)
System Memory Controller
Error Correction Capability : None
Number of Memory Slots : 4
Maximum Installable Memory : 4GB
BANK0 - DIMM1 : Manufacturer1 PartNum1 SerNum1 AssetTagNum1 DIMM Synchronous SDRAM 512MB/64
BANK1 - DIMM2 : Empty
BANK1 - DIMM3 : Manufacturer2 PartNum2 SerNum2 AssetTagNum2 DIMM Synchronous SDRAM 512MB/64
BANK1 - DIMM4 : Empty
Chipset 1
Model : Intel Corporation 82865G/PE/P, 82848P DRAM Controller / Host-Hub Interface
Bus(es) : ISA AGP PCI IMB USB i2c/SMBus
Front Side Bus Speed : 4x 200MHz (800MHz data rate)
Maximum FSB Speed / Max Memory Speed : 4x 200MHz / 2x 200MHz
Width : 64-bit
HTT - Hyper-Threading Technology : Yes
IO Queue Depth : 12 request(s)
Chipset 1 Hub Interface
Type : Hub-Interface
Version : 1.50
Number of Ports : 3
Width : 8-bit
Full Duplex : Yes
Multiplier : 1/1x
Logical/Chipset 1 Memory Banks
Bank 0 : 512MB DDR-SDRAM 3.0-3-3-8CL 1CMD
Bank 1 : 512MB DDR-SDRAM 3.0-3-3-8CL 1CMD
Channels : 2
Speed : 2x 200MHz (400MHz data rate)
Multiplier : 1/1x
Width : 64-bit
Refresh Rate : 7.80µs
Performance Acceleration Technology : No
Power Save Mode : No
Fixed Hole Present : No
APIC 1
Version : 2.00
Multiplier : 1/2x
Maximum Interrupts : 24
IRQ Handler Engaged : Yes
Enhanced Support : Yes
Memory Module(s)
Memory Module 1 : Nanya M2U51264DS8HB3G-5T 512MB 16x(32Mx8) DDR-SDRAM PC3200U-333-600 (CL3 up to 200MHz) (CL2.5 up to 167MHz) (CL2 up to 133MHz)
Memory Module 3 : Nanya M2U51264DS8HB3G-5T 512MB 16x(32Mx8) DDR-SDRAM PC3200U-333-600 (CL3 up to 200MHz) (CL2.5 up to 167MHz) (CL2 up to 133MHz)
Environment Monitor 1
Model : Winbond W83627(T)HF ISA
Version : 2.01
Mainboard Specific Support : No
Temperature Sensor(s)
Board Temperature : 29.0°C / 84.2°F
CPU Temperature : 25.5°C / 77.9°F td
Power / Aux Temperature : 67.0°C / 152.6°F
Cooling Device(s)
Auto Fan Speed Control : No
Chassis Fan Speed : 2860rpm
CPU Fan Speed : 5273rpm
Power / Aux Fan Speed : 1776rpm
Voltage Sensor(s)
CPU Voltage : 1.31V
Aux Voltage : 1.54V
+3.3V Voltage : 3.30V
+5V Voltage : 4.76V
+12V Voltage : 10.76V
Standby Voltage : 4.99V
Battery Voltage : 1.25V
AGP Bus(es) on Hub 1
Version : 3.00
Speed : 8x
Multiplier : 1/2x
Fast-Writes Enabled : Yes
Isochronous Mode Enabled : No
Addressing Enabled : 32-bit
Aperture Size : 64MB
Performance Tips
Notice 224 : SMBIOS/DMI information may be inaccurate.
Tip 2511 : Some memory slots are free so the memory can be easily upgraded.
Tip 2546 : Large memory modules should be ECC/Parity.
Warning 2518 : Mainboard temperature is too high.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
I don't know why Sandra report says that my motherboard temp is too high. And I don't know how come my Power/ Aux Temp is 67 C degree either, it can't be that hot. I eventually got shutdown automatically after using for a while but I don't know how to fix this problem, anyone got exp about this? BTW my PSU is Antec True 430w, should be good for a system with 6HD and 2DVD drives ?
thanks
Farmer
3,334
I think your CPU temp and "aux" sensors are getting mixed up. There is no way CPU temp can be lower than mobo temp.
funnyfenix
516
Originally posted by: Farmer
I think your CPU temp and "aux" sensors are getting mixed up. There is no way CPU temp can be higher than mobo temp.
not sure if I got what you meant there but I think the CPU temp is lower than mobo temp
what I don't know is Power/ Aux Temp stand for which devices/ zones on the system?
Farmer
3,334
DAMMIT!
Sorry. I mean lower. :) CPU temps in no way can be lower than mobo temps, unless you run like a water cooling device. I'm also not quiet sure what aux temps are. Maybe PSU (since it says power)?
Try checking other programs/BIOS for temp readings.
funnyfenix
516
DAMMIT!
you could be right about the CPU part because it was higher and I switched the 3pin connections around to see if it changed anything since I thought maybe they named them wrong :)
I don't know what is Aux Temp/Power is too
