Does anyone know of a motherboard that has support for more than 2 IDE controllers (ie. 4 IDE drives)? I am trying to build a PC that has lots of cheap 80GB IDE drives and one CD-ROM drive (used primarily just to install the Operating System). I've heard of motherboards that have 4 controllers as well as separate controllers boards that might can do the same...but I'm having no luck finding them.
Thanks!!
Thanks!!
