It's at approx. 53-56 c. I have 1 intake and 1 exhaust. My case is a SkyHawk Alum.(Lian-Li look-a-like). I don't plan to cut any holes in it anytime soon, so I was wondering if their are any alternatives?
Would one of those fan brackets that attaches to the PCI slot do any good? If so, where should the fan(s) be pointing on the motherboard? I'm also limited with space in the case. I doubt I could fit no more than (2) 80mm fans.
Thanks!
Thanks!
