Motherboard replacement: Upgrade or downgrade?
Crazy Joe Davola
Hi,
My computer (Prescott 3GHZ, 2GB RAM, saphire raidon x1950 pro) had it's MB replaced due to a malfunction.
My old MB was an ASUS P5GD1-VM. It's 915G based (onboard graphics adapter disabled), uses DDR1 and is feature heavy:2 IDE interfaces (so I can connect my cdrom and secondary HDD separately), surround exits( that I don't use), and parallel port which I use for a custom project.
The new MB that I received is the Intel DG31PR. It's G31 based, uses 800MHZ DDR2 and has the least features on an MB ever: only 1 IDE interface, no parallel port, and half the sound ports. Also it LACKS A HEATSINK ON THE SOUTH BRIDGE which seamed strange and alarming considering that both my older computer, my older MB and my newer computer all have one.
I am concerned because even though the new board uses a newer chipset and faster memory, it seams to be very low-end. I'm considering whether to ask the shop for a different MB or to stick with what they gave me. The alternative will probably be a 915p board with DDR2.
I don't overclock.
Questions:
1) Should I expect better, same or worse performance with the current MB, compared to what I had before?
2) One of the alternatives they had was a fancy Gigabye model with 915P and DDR2. Will that perform better/worse then what they gave me?
3) Is it normal/healthy for the south bridge to lack a heat sink?
4) Will putting both my secondary HDD and CDROM on the same IDE interface will serve a significant performance hit when using those drives? If so, will this only happen when using both at the same time or also when using them one at a time? (my OS HDD uses SATA.)
Thanks for reading all of this, and big thanks in advance for any advice.
zCypher
6,115
171
If you don't overclock and you have sufficient cooling in your case, I doubt it will be a problem. Otherwise you may want to add a heatsink? I am waiting for my G31 board which should arrive today or tomorrow, mine is an MSI. You're right about the features, it is basic. I don't think that is necessarily a bad thing unless you want/use those extra features. I was going to get a P5Q but the G31 board was less than half the price, and it's not for a high end system anyway.
If you have both cdrom and hard drives on the same cable, I do believe this will only impact performance when attempting to use both at the same time. If your HD is SATA, this means you have a HD #2 on IDE + CDROM on IDE right? Hopefully someone here can confirm but I do think it's only if you access both at the same time that it might display a hit in performance.
As for MB performance... I would think that the G31 should still be quite good, but I don't know your old board so it's hard to say. All the reviews I've seen for the G31 have been positive, people have been happy with their boards.
