I?ve got an EPOX 8K5a3+ and it?s doing some weird things. I first installed the motherboard, then ran the Maxtor drive utility to wipe the disk clean, and when the utility loaded up, it was NOT picking up any devices on the IDE channel. I moved the drives over to another computer and the diagnostics ran fine and the disk was low-level formatted ok. I then moved the hard disk back over to the computer with the NEW EPOX board and started the Windows setup and format. I booted the Windows 2000 CD and it hung in setup after it loaded the setup files off of the CD into memory with a stop error related to ?Ntoskernel?. I thought that it could be CPU, so I swapped CPU. The setup booted and loaded files just fine and actually got to the installation menu and began a format. A little way through the format, the computer essentially restarted itself. Any ideas??
PARTS RULED OUT (AS TESTED: WIll add more, stay tuned)
hard drive - maxtor 30gig (low level formatted just fine on another computer)
