GEOrifle
While removing CPU cooler accidentally broke CONDUCTIVE POLYMER CHIP CAPACITOR # KO 157 6K 236. It's yellow and square, one side lightly longer than another size 3/8" x 3/16" with short side legs.
Similar like this
https://www.amazon.com/Tantalum-Cap...DUCTIVE+POLYMER+CHIP+CAPACITOR++KO+157+6K+236
It's Dell Precision t3600 Server, chip is located nearby CPU itself.
Couldn't find it even at Ebay. Can i replace it by something similar?
I got similar chip KO 157 6K 527 instead 236. Will it work?
Here is the SPECS in PDF format :http://www.farnell.com/datasheets/718274.pdf
Also http://www.digikey.com/Web Export/Supplier Content/Kemet_399/PDF/Kemet_TantalumSMCap.pdf
From where markings at lower level 512 means
512 = 12th week of 2005 0r 236 = 36th week of 2002
Also Print Week Code: 1st Digit = Year 2nd & 3rd Digits = Week "513" = The 13th week of 2005
KO-KEMET Organic SIMILAR
157- Picofarad Code SIMILAR
6k- (6-Rated Voltage) (k-KEMET ID) SIMILAR
If this is correct then CAPACITORS KO "157 6K 236" and "KO 157 6K 527" are same just manufactured date is different.
Appreciate your help. Thanks.
Similar like this
