As I was taking pictures for another question I had about hooking up my case fans to my PSU I was looking at my motherboard, which I'm 99% positive I mounted right because all the holes lined up properly and it fit perfectly into the back i/o panel. But when I looked at the PCI and PCI-E slots on my case and then looked at the slots on the motherboard they don't look like they're lined up. I'm building this computer as I go and this is my first build so I don't have anything to plug into it to see if they're okay. I took two pictures which came out a little dark but if you turn your brightness up I'm sure you can see them okay =].
http://img504.imageshack.us/img504/1791/pict0686ml0.jpg
http://img504.imageshack.us/img504/3323/pict0687vj9.jpg
see how they don't look lined up? but it fit in all the holes on the case right and as i said the I/O panel is lined up correctly in the back. It's a GIGABYTE GA-965G-DS3 rev3.3 motherboard [ http://www.newegg.com/Product/Product.aspx?Item=N82E16813128018 ] and the case I'm installing it to is a COOLER MASTER Centurion 5 CAC-T05-UW [ http://www.newegg.com/Product/Product.aspx?Item=N82E16811119068 ]
sorry for all the links I just want to be as clear as possible and as this is my first time building I want to make sure I'm doing everything the right way. So if anybody would be able to tell me if that looks right or wrong and if so how I fix it I'd highly appreciate it. Thank you for your help.
