- Sep 2, 2006
- 7
- 0
- 0
If you want to run your computer with the motherboard outside of its case, what surface should you put it on? Can I just set the motherboard on my (sawdust and glue, or as Ikea calls it, "wood") table? Or should I put it on the anti-static bag that it came on?
(The reason I don't want to mount the motherboard inside the case is that the case may be contacting the motherboard in some place and shorting it out, so I want to remove this possibility...)
Thanks,
Mike
Thanks,
Mike
