Hello,
Complete PC specifiation can be found below:
I'm looking for a second opinion regarding the following:
I have a system with an overclocked Prescott-2M (3.73GHz EE) at 4.16GHz at default Vcore that runs at 4161MHz when idle in Windows XP. If I start anything power intensive such as an Nvidia 3D demo or SuperPi, and refresh thus check CrystalCPUID readings that confirm the CPU is slowing down by around 200-300MHz does this mean that:
a) The motherboard cannot sustain enough stable current thus the CPU is forced to run slower. In such case the FSB is slowed down as a result of lack of steady current.
or
b) The PSU is struggling thus provides less power to the CPU which in turned is forced to slow down.
or
c) Both a) & b)
System specification:
Asus P5AD2-E Premium motherboard
Crucial Ballistic PC6400 DDR2 RAM
BFG 7800GTX
2x SATA HDD's
1x Optical drive,
1x PCI TV/Radio card
Enermax 550PSU with 24A on +12V line
Default Vcore
1.6V chipset voltage
1.50V FSB termination voltage
Memory at 729MHz
Please note that the CPU is not throttling in any case explained herein as proven by ThrottleWatch 2.01 and the CPU temp is always 60C at most.
At 4.1GHz the CPU will always run at ~4100MHz leading me to think 4.1GHz in on the border line when the power drain on the +12V line is so high that anything higher causes the qualify of current to diminish. With this said the Asus probe still reports healthy voltages for each. I can very slightly remedy the problem above 4.1Ghz by improving on the Vcore or increasing the chipset voltage. Even with this we're talking an extra 30MHz. At 14x300 the CPU will never report above 4.17GHz in Windows and once SuperPI or similar is started it dips to around 3.7-4GHz.
Would appreciate others to comment.
Many thanks,
or
or
c) Both a) & b)
BFG 7800GTX
2x SATA HDD's
1x Optical drive,
Default Vcore
Memory at 729MHz
Many thanks,
