motherboard monitor
Boonesmi
14,448
works great, but i think support was stopped a couple months ago. (ie. new motherboards wont be supported)
Ketchup
14,559
248
It still works great, even on motherboards that aren't "supported." Just means you will have to set the temp sensors by hand.
bentz626
31
are there any other monitoring programs that will support the newer mobos? I know the mobo I'm using now is not supported my MBM.
Ketchup...how does that work? would I have to select a similar motherboard of the same company and try that? How do you set the temp sensors by hand?
thanks
Geoff
