Hehe, thanks for all your responses.
I am a software developer (5+ years of C++, VC++ and VB), and I firmly believe that the user should NEVER have to RTFM. If the program is not intuitive, then it's the fault of the programmer (or, in a large company, the software interface research and development team). How many of you actually read the manual for Windows, or MS Word, or Netscape? That software is so easy to understand (and to crash, of course), that the user can simply sit down and start using it. And believe me, MS Word is MUCH more complex than the Motherboard Monitor.
Even if I need to configure it first, what's with all those little controls/buttons in the corner of the window? Why use flat buttons? Why not have a titlebar by which the user can easily drag the window? Bleh. I'd do their interface for $500 😉
And they don't even have a wizard to guide you through the set up. Come on, freaking WinZip has a wizard!
Take care, motherboard monitor lovers and all others 🙂
