Motherboard, Memory, & CPU Overclocking Guide
deeppow
31
Hope it is of use to a few of you. Suggestions for improvement and corrections are very welcome. Particularly improvements related to Intel systems are needed. :D
Motherboard, Memory & CPU Overclocking Guide Guide has been reconfigured to use a frames interface due to its large size. If you find broken links please let me know.
Table of Content
Introduction
A Simple Perspective of Overclocking
A Simple Overview of Memory
The Mechanics of Overclocking the Motherboard, FSB, and CPU
.... Determining the Maximum FSB for nForce2
.... Determining the Maximum Memory Speed
.... Determining the Maximum CPU Speed
.... Locked CPU
.... PCI and AGP Buses
Testing
Results - A Couple Initial Overclocks
.... A nForce2 Motherboard
........ How Well Does Dual DDR Work
........ Overclocking the nForce2 FSB
........ Memory Settings and Their Effect on Overclocking for Dual Channel
........ Final Overclock of My nForce2
.... A KT333 Motherboard
........ Overclocking the KT333 FSB
Summary
Caution
Should you find this guide useful you might consider a bump so it is available to others. Otherwise I'll let the thread die due to age, passing on to that great bit bucket in heaven.
