- Jan 22, 2008
- 9
- 0
- 0
Motherboard MSI K9N SLI V2 running Twin 7600GT MSI video cards -
4 gb PC6400 ram
AMD 2.6 X2 chip
2 - NEC dvd reader/writers.
2 250 gb Samsung Hd's
Approx 5 weeks ago Windows Vista 64 bit crashed when my son was using the computer. Even to the point where safe mode would not start up. Inserting my Vista 64 DVD the computer would not respond with the "Boot from CD " message and went to the windows boot options. At this time I assumed there was a hardware conflict. So from here I did the following:
Having the 2 DVD readers I placed one at a time in the system so only one would be present with no results. Installed a good known Dvd unit from another machine and same results.
Tried different cables to DVD's - no change
Removed memory 1 stick at a time with same results.
An interesting point to make is that the CD version of Windows XP would read just fine. Also if I boot into my hard drive with 32bit Vista I can play DVD's no problem. 32bit or 64bit DVD's have the same issue.
At this point I consulted with a computer guru friend who thought the driver chip on the motherboard was defective. Consulted MSI online tech support and they thought the motherboard was defective. I shipped the board to them under warranty and 2 weeks later received the board back (Was the same board I shipped to them) and still had same issue. Calling their tech support I was able to talk to a tech who stated that they dont get the information I typr in on the online form. So they sent me a drop ship label and I sent it back and again 3 weeks later (same board I sent them) hook it all up and same issue.
At this point I am a bit frustrated in the fact that either MSI did nothing or missed the issue OR what else is left for me to check?
If the current DVD's units play DVDs okay then isnt that a good proof that they are working properly?
What else am I missing here? Also I built this system myself and it has worked flawlessly for 7 months until the issue started. I am really really trying to avoid replacing the motherboard with a different model in order to get my main system (with all my wifes files needed) up and running faster.
Thank you for the look over and appreciate the information.
4 gb PC6400 ram
AMD 2.6 X2 chip
