All other components I can grasp, if I spend enough time reading tech-articles, but motherboards are dang difficult.
I am a gamer, so as I understand it, my money is better spent on GPU, memory etc., than on the motherboard - so the exercise is choosing the exact motherboard that won't inhibit performance from the rest of my rig.
But the articles often seem to praise motherboards for their ability to overclock, sli/crossfire-compatibility and for compatibility with future CPU's. These are all qualities, that I don't care about: I don't (i.e. know how to) OC, I'm probably never going to try sli/crossfire, and when I do upgrade my CPU, I upgrade my motherboard at the same time.
As I recall, last time at built a rig, I ended up throwing (too much?) money at a motherboard, because I couldn't figure out what I needed.
I'm planning on an Antec P182 case, with a CPU Phenom II X3 720 BE and GPU probably an overclocked radeon 4870, maybe a 4890.
Memory comes after the motherboard. I understand that the motherboard dictates whether the memory should be DDR2 or 3, but the differences & advantages between the two is - at least for the moment - confusing to me.
Any tips on what I need? Maybe pointers to any up-to-date "motherboards-for-dummies"-articles?
Thanks in advance for any help.
