Motherboard for Opteron 165
Alydis817
10
Maybe its bad luck... maybe I'm just a DFI Ultra-D nub..but I've had it with this board.
I have an Opteron 165 and OCZ Gold 2x1024 DDR500 3-4-3-8 (OCZ5002048). The DFI refuses to post with both sticks of memory in it (either dual channel, or single). If I clear the CMOS, I can get it to boot both sticks in single channel ONCE.
Anyway. So, I'm about to drop the DFI and I'm looking for another motherboard recommendation. Anandtech gives the Asus A8N32-SLI Deluxe -- but that article is quite old. I also don't need SLI. Is there a similarly featured board that can hit around 290ish FSB?
Thanks in advance
Puffnstuff
16,187
4,871
Are you using the most current bios for your mb? Have you checked to see if the mb supports that ram? What voltage are you using? You should have at least 2.7v or higher.
Alydis817
10
I am using the latest bios (2005/11/14)
I have checked compatibility, yes.
Voltage is currently back to 2.6V -- I did try 2.7V.
Jan 26, 2006
84
have you tried different sticks of ram? oh and btw, there's an OCZ forum here , talk to OCZ steve , real nice guy
