Motherboard for IBM Netvista case?
GnatGoSplat
1,155
I bought one of those spray-painted IBM Netvista cases from Ebay.
They seem to believe the case fits Flex ATX motherboards, but the case has 4 slots and I've never seen a 4-slot FlexATX motherboard. 4-slots sounds more like MicroATX to me. Does anyone have this case and know if a MicroATX will fit? Are there any MicroATX motherboards in particular that fit well in this case?
I'm leaning towards an inexpensive Socket 370 or Socket A solution.
yodayoda
2,958
uATX motherboard will have problems because the drive bay encroaches directly over the motherboard. i am having a problem right now putting a mini-ITX mobo in there because the CDRW rubs the ATX connector. i tried putting a MSI nForce board but the memory sticks prohibit any type of CDROM drive. it is very tricky to get anything to fit.
fxsts
1,794
Pretty much all the FlexATX boads should fit. I believe that some narrower MicroATX boards could fit as well.
ajb35
316
Asus p4s333-vm fits fine. I am having a clearance problem with the ram and cddrive though by 1/4". Need to find a shorter drive.
GnatGoSplat
1,155
Thanks for the info, I've received the case and cleaned off the paint (came off the metal pretty easily with lacquer thinner).
Looks like most any MicroATX mobo should fit, except I would probably need an ATX power cable extension.
Also, where would I find cards with the proper short backplane? Is there a name for them?
10102BORG
93
Go to pricewatch and search for "low profile" cards, these are made for rack mounted systems. The video cards tend to have older chips and are on the expensive side when you consider its performance. Aside from network, raid and scsi cards there isn't alot of low profile cards out there.
