Motherboard for FX8120?
lsv
It appears I'll be able to purchase an 8120 locally to upgrade my aging BE-2350 based linux server.
My use cases are:
Web host (Nginx/SQL)
Media host (flexraid raid-f across a shit ton of drives with some spare adaptec sata cards)
VMs (Virtualbox as a service)
Additional services as needed
No overclocking
I'm leaning towards a Gigabyte GA-970A-D3 for the price or perhaps an Asrock 970 board as they're both cheap.
Am I good to go with either? Any warranty considerations I should know about?
Lsv
Yea any decent 970 board shoud be fine. Just make sure it can support the 140watt CPUs and you will be fine.
I'm buying the 8120 for $100, 8350 is $195.
Thoughts?
$100's a little high, but not bad. It's competitive.
Something to keep in mind, there are a number of 760 boards that the manufacturers have reworked to be AM3+ compatible. I personally ran an FX 8150 on an MSI 760GM-P34(FX).
You don't have to spend 990FX money on a board, if you don't want to.
Yea $100 is competitive, I'm certain I could bargain down but it's from HWC, a local enthusiast forum and it's BNIB. So I'm ok with that 🙂
The board I'm going for is this Gigabyte http://www.canadacomputers.com/product_info.php?cPath=26_1207_1205_335&item_id=042705, $77 after IR and MIR which I always do. It's not 990FX money at all I think. I just wish I could find one used for cheaper, but most 970 boards are dropping price at the retail level causing a loss at the consumer re-sale level.
Lsv
