Motherboard Fan Power Ratings?
Essence_of_War
2,650
4
How does one figure out how much power their motherboard fan headers can supply?
I have an AsRock z77 Pro4 in a carbide 500R. I was planning on switching/upgrading some of the fans, which are currently connected to the carbide 500R's fan controller, and I was planning on connecting the new fans to my motherboard fan headers, possibly with 1-2 3-pin Y splitters in the mix.
Ketchup
14,559
248
I don't have the exact number you are looking for on hand, but I have split 2 120's on single motherboard fan headers before, and haven't had any issues. Get over two, and you really want a fan controller.
Golgatha
12,429
1,120
Anything over 1A and you should probably think about using a fan controller directly attached to the power supply.
Essence_of_War
2,650
4
Anything over 1A
Shouldn't be anywhere close to that. Each fan should be < 1W.
I'm looking at driving a total of 2x120mm and 2x 140mm fans off of 2 3-pin headers. Each fan should be < 1W, and 1A @ 12V -> 12 W.
crashtech
10,695
2,294
I thought the z77 Pro4 had plenty of fan headers, what's the deal, are some of them not controlled by the BIOS?
boondocks
135
11
When I'm not water cooling a particular build, I contact the manufacturer and ask them outright what the fan headers are rated at.
For the last several years the mainstream Gigabyte boards generally have headers rated at 1A.
Compman55
1,241
Back in the day the rule of thumb is 2 per header. These specs are super hard if not impossible to locate. Often the manufacture will give a generic response.
