Motherboard does not POST
benwood
107
I'm building a HTPC with a Pentium 4 3.2ghz Northwood CPU, two 512meg
sticks of Mushkin PC3200 ram, Zalman CNPS 7000-A AlCu heatsink, Arctic
Silver Ceramique thermal compound, and a Intel 865 PERL motherboard. The
power supply I'm using is a 400w Seasonic Super Silencer. When I 1st
powered the computer the heatsink fan started up and I got a very rapid
series of beeps. I thought the problem might be caused by CPU as the
Intel 865 PERL instruction manual stated that seven beeps indicates a
CPU problem though there seemed to be more than seven beeps sounded in
the attempt to boot.
So I removed the motherboard and power supply from the case, removed the
heatsink and CPU, cleaned off the old thermal compound with 91%
isopropyl alcohol and reapplied a new coat os thermal compound. I also
removed and reinstalled the two sticks of Mushkin RAM. I left the
motherboard out of the case, jumpered the off/on pins on the motherboard
and reconnected the power cables.
Now when I try to boot the system I no longer get any beeps. Instead
after about 5-7 seconds the fan on the heatsink stops spinning. I've
tried attaching a video card but the machine never gets far enough along
to output video. Any idea as to what's wrong. I hope I havent fried by
motherboard or CPU. Thanks. :(
IEC
14,604
6,091
Originally posted by: qbackin
What is your psu? And the rating on the 12v rail?
If you read the OP you will see it's a Seasonic 400W which is PLENTY. ;)
Peter
9,640
You know that the power-button connector is for a MOMENTARY button not a PERMANENT switch? If you "hold" the connection for five seconds, the hardware is going to switch everything back off.
benwood
107
My thanks to qbackin, ariafrost, Kensai, lenjack, Jayczar and especially Peter for their help. The problem was caused by me jumpering the on/off pins on the motherboard. When I removed the jumper the motherboard POSTed.
