hi ok so i wana upgrade my graphic card from a nvidia geforce 8600GS to a XFX HD-489A-ZDEC Radeon HD 4890 Xtreme 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card.
It can be seen here http://www.newegg.com/Product/...x?Item=N82E16814150360
yes so the only problem is that, i am not sure if my motherboard will support that new graphic card. I dont want to spend 200 dollars only to find that my motherboard is not compatible
with the graphics card.
soo... perhaps you people can advise? I am using the Acer Aspire M5630.
Motherboard is ACER EG31M
power supply? umm im not sure how to check.
ive tried googling my motherboard, googling the graphcis card, i still cant find whether they are compatible or not. Any help would be appreciated! thanks
