It seems that most computer buyers don't realize how much power they waste (and how much money it costs them over the years) by using a video card instead of buying a motherboard with built on video. I'm looking for a name brand motherboard (Asus, Abit, Gigabyte, EVGA, Intel, MSI, etc) that can play 1080p smoothly with its built on video. I don't do any gaming.
Perhaps I should first look at what video chipsets will do that?
Then search for motherboards that use those chipsets?
When you go to vendor's websites they usually don't have the DVI OUT option in their search parameters.
DDR-3 has lower power consumption as well as minor improvements in performance (also its often even cheaper than DDR-2 right now) so hopefully the motherboard will use DDR-3 memory. 4 memory slots would be nice but with 4gb chips so common now 2 slots would be fine.
Firewire, USB-3, E-Sata are all nice but I can get cheap PCI-Ex1 cards for those If I need them later. (Of course when USB-3 catches on you'll only need 1 USB-3 plug on your device that will output to a hub that supplies however many devices you use. Thunderbolt has far more capabilities.)
ATX, M-ATX, Micro-ATX should all be fine. I'm not sure if an ATX board normally consumes more power than smaller boards everything else being the same. Perhaps someone knows?
I wanted to use Socket 775 because the CPU's are so cheap on the used market. I haven't seen any i5, i7 CPU's going for much less than $100 on the used market whereas the Socket 775 Core 2 Duo's often go for as little as about $40. I don't need the higher CPU speed right now.
