Motherboard boot problem, Please Help!!!!
Girospeck
Hi, when i boot my system, it tells me that it has failed a memory test. I cannot get into bios or anything else. I only see a black screen and none of the keyboard comands work. I didn't have a chance to create a back up
floppy so I dont have that. This happened after I changed the memory frequence in the bios to 150%. What should I do?
Thanks
Yea, it sounds like CMOS needs to be cleared....easy to do with the jumper.. .
UNLess you have ASUS mobo, some of which don't have jumpers.....You gotta actually short out some solder points on the mobo where the jumber whould be.....sheesh what a PITA!
Dan
Originally posted by: Girospeck
I have an ASUS A7N8X Deluxe
Tip: ALWAYS leave the memory at 100% of the FSB, it performs best that way 😉
Refer to page 8 of your manual for the location of the CLRTC1 jumper. Unplug the computer from the wall, switch the jumper to the alternate position for about 15 seconds, and then switch it back. Now plug the computer into the wall and see where you're at.
Thank you, that fixed the problem. I dont want to make the same mistake twice so do you know of any good sites for overclocking a AMD 2500+?
This one. 🙂
I suggest adjusting the multiplier down and the memory up, keeping your cpu at around stock speeds. Test your memory with memtest86 (prime too if you're feeling saucy) until you reach its limit. Then back off a notch and then crank up your multiplier, increasing voltage up to 1.85v in small increments if you have to, depending on your temps. Less than 60C under load is ok if your comp is stable. Good luck!
