I have a home-built PC with an ABIT KG7 motherboard and an AMD Athlon 1.33GH Socket A CPU. Everything was running fine until I decided to add another hard drive. When I opened the case, I noticed that it was very dusty inside. I used my vacuum cleaner's hose with a plastic head to suck out the dust. I used it around the motherboard and the various PCI cards. Afterwards I installed the second hard and turned on my PC. All of the fans, components and monitor fired up, but I get nothing displayed on my monitor and no beeps. I checked al of the seatings, connections, etc.
The BIOS appears not to be working any longer. Could I have killed the motherboard while cleaning inside my PC? Is there some way I can check to see if my motherboard is still working? Any thoughts would be appreciated.
Thanks.
Thanks.
