motherboard advice?
Maezr
333mhz (333 AND 400 is a big plus, but not required)
onboard audio
onboard nic
the ability to have more than 4 eide devices (4 hds + DVD-RW) ie, raid controller/etc
usb2
reasonably okay at overclocking
and I'm trying to keep this as cheap as possible. for an athlon XP, by the way. also, what ram would you get with the board?
thanks a bunch
Spend some time and go through the stickied threads at the top of the forum 🙂 I'm not an AMD guy. So I can't really direct you towards an AMD board.
