Most ridiculous selfie ever not by Russians
Gooberlx2
15,381
Does the body explode when hitting the ground, if the fell?
Gravity, a mere nuisance to Christian, was a terror to Pope, Pagan, and Despair. To the mouse and any smaller animal it presents practically no dangers. You can drop a mouse down a thousand-yard mine shaft; and, on arriving at the bottom, it gets a slight shock and walks away, provided that the ground is fairly soft. A rat is killed, a man is broken, a horse splashes. For the resistance presented to movement by the air is proportional to the surface of the moving object. Divide an animal’s length, breadth, and height each by ten; its weight is reduced to a thousandth, but its surface only to a hundredth. So the resistance to falling in the case of the small animal is relatively ten times greater than the driving force
http://irl.cs.ucla.edu/papers/right-size.pdf
olds
50,071
744
I always assumed a selfie was a picture and not a video.
Live and learn.
