Most Quiet Hard Drive
mechBgon
Oct 31, 1999
30,699
SilentPCReview.com may be worth checking. The quietest of all would probably be Ultra320 SCSI... on the far end of a 10-meter SCSI cable, in your basement or wherever :D I haven't seen anyone do that just for quietness, however.
Net
1,592
that's out of my price range ;(
maybe some sort of 7200rpm sata
mcurphy
4,150
8
I have the 320GB WD SATA II and it is very quiet. I have heard that the Seagate 7200.1's are a little noisey, which is what drove my decision towards WD. I am glad I made the choice I did ;)
Cheezeit
3,298
My WD 250 KS is the loudest thing in my rig when it seeks, but that's because the rest of the rig is so quiet :D. The WD's are supposed to be the quietest consumer SATA's.
PhoenixOrion
4,312
WD 250 JD
WD 500 KS
If still bothers you, try internal enclosures and fit them into a 5.25 bay.
yosuke188
2,726
Samsung is known to create one of the quietest hard drives. I have a Samsung HD501LJ, and it's really quiet, especially if you suspend it in the case.
The latest WD hard drive (AAK) is also very quiet from what I hear.
Jiggz
4,329
I'll go with the 250JD from WD. Just plain quiet! And you can make it even quieter by suspending it or sound insulating it!
Roguestar
6,045
This. Getting a suspension or rubber mount or something along those lines is a good way to eliminate the cage rattle.
