Most popular flavor of linux to learn for work?
Nitemare
35,461
4
I have a couple years experience in UNIX/AIX and I was thinking of trying fedora, debian or freebsd to diversify my skillset..
Bateluer
27,730
8
Most popular right now seem to be Gentoo, Fedora, and Debian. You might have better luck in the OS forum though.
skace
14,488
7
The only version of linux I've seen at my work is Redhat. I believe it is because of support and not necessarily overall functionality.
Armitage
Banned
Feb 23, 2001
8,086
What kind of work?
Whatever your sysadmins like to use would seem to be a good answer.
I find that as primarily an end user on the stuff they take care of, it makes little difference to me - our guys are partial to SuSe.
On my desktop and systems that admin, I use what I like.
Nitemare
35,461
4
Originally posted by: n0cmonkey
FreeBSD isn't Linux.
I know, but I am 10 times more familiar with Unix.
Thanks for the suggestions so far
Originally posted by: Armitage
What kind of work?
Currently laid off so just seeking to pep up my resume and learn some things
sciencewhiz
5,885
8
For home users maybe.
For business, in the US, it's probably Redhat Enterprise, then a big gap, then SUSE Enterprise, then another big gap, then everything else. In Europe, reverse Redhat and SUSE.
Nitemare
35,461
4
K, redhat and fedora are essentially bastard twins separated at birth, no?
Any major differences?
n0cmonkey
42,936
Get one of the redhat enterprise clones. I think white box and centos are two of them.
Nitemare
35,461
4
Good idea, looking into those now.
sciencewhiz
5,885
8
I've installed Redhat Enterprise 3 and CentOS 3 & 4 and the only difference I found in CentOS is that the update monitor does not show the advisory information in CentOS. Never tried white box or lineox. When I did my research before, white box took a while to update and lineox charges for updates, so I went wtih CentOS.
sourceninja
8,805
65
We use gentoo at work, but not seriously. For the most part we still keep with the old standby of Sun box's and solaris. Yea its not linux, but it has a level of support that just can't be beat at educational prices.
For learning linux, i'd suggest you start with ubuntu and then move on from there. Once you learn a linux, the rest is just a small amount of syntax and leanring the package managment, all easy stuff.
