- Mar 31, 2001
- 4
- 0
- 0
Greetings:
Here's my problem. I have an ISDN line running to a Netgear RH340 router, which in turn is connected to 3 computers (2 WIN98/ 1 win95) with CATV UTP cable.
One of the WIN98 computers works fine. It's using an Intel EtherExpress 16 NIC to access the router. The other two computers can't see the router or ISDN line at all. Both of them are using recently purchased SMC EZNet PCI cards. Their problems are:
Computer #1<win95 system>: I've repeatedly uninstalled and reinstalled all networking protocols and adapters, including the NIC, and redone all the bindings. Even after all this the system CAN'T PING ANYTHING, and CAN'T RUN WINIPCFG.exe. This is very unsettling, as every time I try to ping the router (or even loopback, 127.0.0.1) I get an "error 10091". The Netgear software, when installed on this computer, says the system has no IP address, even after multiple reboots and re-installation of all networking-related stuff. What could this POSSIBLY be?
Computer #2<win98 system>: This one is even more infuriating. I install the SMC EZNet NIC, and get nothing. No "new hardware found" no hardware install wizard, no NOTHING. The computer acts as if the two different PCI slots I've tried placing the NIC card in are both dead. Furthermore, there is no link light on the NIC even when I connect it via CatV cable to the router. Surprisingly, the ROUTER shows a link light for this system's slot. IOW, I'm getting a 1-way link light: the router thinks there's a NIC card plugged into it, and the NIC card disagrees.
Any help at all would be most appreciated as I am approaching a point of ritual suicide over these incredibly illogical problems.
Thanks so much in advance,
netwerkboi
netwerkboi
