Most basic SQL question and I still am making a mistake.
KAMAZON
1,300
www.alirazeghi.com
UPDATE MemberDetails
SET
STREET = '45 Upper Road',
City = 'New Town',
State = 'New State',
ZipCode = '99112',
WHERE MemberID = 4;
Server: Msg 156, Level 15, State 1, Line 8
Incorrect syntax near the keyword 'WHERE'.
I have also tried it with:
WHERE MemberID = '4';
WHERE MemberID = 4
with open close parens:
SET
City = 'New Town',
ZipCode = '99112',
WHERE MemberID = 4
This is MS SQL 2000 running on my XP pro box. Any suggestions? Thanks.
Atheus
7,313
You don't want a comma after the:
ZipCode = '99112'
as you're not continuing the same bit if you know what i mean...
Also - is ZipCode an integer or a string? If it's an int you don't want those quotes around it.
SET
City = 'New Town',
ZipCode = '99112'
WHERE MemberID = 4
or
SET
City = 'New Town',
ZipCode = 99112
WHERE MemberID = 4
/edit: LOL beaten to it twice
Evadman
Administrator Emeritus<br>Elite Member
Feb 18, 2001
30,990
In case no one has mentioned it yet, you have an extra comma after the zip code.
yllus
Elite Member & Lifer
Aug 20, 2000
20,577
432
I believe the answer is to reinstall SQL Server. ;)
