I dont know about n e one else, but id like my computer to be neat, orginized, and not have to make a whole operation, or pay 100+ dollars for a case that i can throw more fans in. I thought of a easy, cost efficient way of making youre comp cooler..
First, get 2 fans.. 92mm or bigger reccomended
Then get a 12 inch long pvc tube so it can fit the outside of the fan blade (snug with the hole)
Connect the 2 fans to teh pvc pipe with both fans blowning towards eachother
this causes them to have great pressure.
Drill 6 holes 2 inches apart on 1 side.
These holes can be about the size of about a nickel
run tubing from that hold, and then seal around the edges with caulk or something
place tubing where hot spots are in case (heatsink)
you can now position these whereever you like
its best to drill holes for the tubes in the bottom of the case
I suppose you can do the opposite to make a vacum
and suck air outta the case
to do this, point the fans away from each other
well, my job here is done
tell me waht you think
laters..
I M virtualskate3k
Site: www.junktrunk.net
-=- Mike
laters..
I M virtualskate3k
-=- Mike
