Morgan-based Durons: Which ones and what's better than original durons?
tdawg
2,215
Hello All,
I will soon be upgrading my parents computer and am curious which Duron's are based on the Morgan core? Also, what's different between the Morgan-based durons and the previous durons? Is it just clock speed, or do the morgan's have new technology similar to the Athlon XP's? Will I notice big performance differences between the original durons and the new morgan-based durons?
I haven't dealt with durons and I don't keep up with their technology. Normally, I would go for an Athlon XP, but cost is an issue and they don't need that kind of power. Any help would be greatly appreciated.
Thanks in advance.
~tdawg
Priit
1,337
Morgan-based durons are all durons starting from 1Ghz (last spitfire was duron 950). Morgan has all the new features (SSE, data prefech, on-die thermal diode, little lower power consumption etc.) of athlonXP (only difference is duron's 64kb L2 and 200Mhz FSB as always).
Duvie
16,215
Priit pretty much sumed it all up....still a good chip though the l2 cache is downsized from the xp's
theoretically since the xp's were noticing 10-15 percent in most applications the duron should be a 10-15 percent advantage over the same speed spitfire...
Couple a duron morgan core with a good integrated board and you have a cheap fast solution....
Duvie
16,215
I believe it comes in the same xp packaging, meaing most likely it will require the fill and bridge method of the athlon xp's...
tdawg
2,215
what's the best integrated motherboard to pair with the duron?
thanks for all the previous help.
~tdawg
Duvie
16,215
Well the best integrated mobos are nforce mobos due to there gf2mx onboard video and 5.1 sound...However that makes them expensive and almost takes the savings away from a more budget duron system...
I now there are many good intergrated mobos...you want to sticvk to the km133a boards as they have superior onboard video cards...
i recommend going to www.tcwo.com and look at the biostar or microstar boards...Also they sell the durons but order over the phone and ask for the p[ricewatch duron price as it is often 10 bucks cheaper then the online price. I bet you will be hardpress to find a much beetre deal in terms of shipping and price on the net...and from a extremely reputable dealer...
Priit
1,337
AFAIK morgan-durons are using the old packaging and are as easy to unlock as spitfires...
kAlla
64
The reason I ask is because I recently purchased a 1ghz oem duron from newegg. I tried the pencil trick on it and it didn't seem to work, so I thought I did something wrong.
I did notice that the bridge were like this, not like this.
Is there any way I can tell if I have AFAIK core without having to remove the heatsink?
Duvie
16,215
The difference is ofcourse the newer xp's and I still believe morgan core durons have the laser cut bridges but also a valley or hole that goes slightly deeper. To get it to work requires filling in the valley with a non-conductive material and then applying with a defogger kit close the bridge...be clean and make sure non are touching each other.
It appears to me there is a slight discolored area running perpendicular to the bridges. I think thank is the slight gauge or valley I am talking about.
hope this helps....
Damascus
1,434
<< what's the best integrated motherboard to pair with the duron? >>
The VIA bashers would say the ECS K7S5A or whatever that blasted thing is called.
It has LAN and sound built in.
VirginiaDonkey
1,704
the 1ghz-1.2ghz Morgan Durons are cut exactly like the spitfire durons. I have one, I know.
I used rear window defogger kit to close my L1`s. it was harder than the spitfire durons because there are 5 bridges now instead of 4 and they seem closer together, they may not be, just seemed that way.
my morgan duron runs at 1.2ghz and is happy to do so!
