Win 7 ultimate.
Now, my PC has gotten into a state where the browser 'back' button stopped working, so I need to just go to new sites. Right-click back button still works.
The mouse wheel isn't scrolling a window, but the scroll bar still works in one - but not another.
I have some notepad windows open. I can alt-tab to bring them up but nothing is clickable - I can't click to save the documents.
On another note - literally - while playing World of Tanks, I've noticed periods of lag/hang where I then hear the OS make that two-note sound it makes when you disconnect a USB device - two notes, one middle sound the next lower. The only USB devices I had hooked up are headphones and kindle, neither of which should cause that. Few times an hour.
Update: I closed a couple programs that were unresponsive to clicking, and now the notepad windows are clickable again.
There seems to be something in one breaking others. Still not sure about the thing interfering with the lag and two note sound. I unplugged the kindle to see if it goes away, but plan to reboot also.
