Unsafe levels of PFOA were found in the water supply in NY around Hooksick, Petersburgh and North Bennington.
The EPA knew by June at the latest (some reports claim they knew in 2014) that there were unsafe levels in the public drinking water supply but did not send out a public notice until mid-December:
And it wasn't until December that residents began using provided free bottled water in Hoosick. Some surrounding areas didn't get bottled water or water warnings until Feb.
This issue spans party lines (Cuomo is a democrat) and state and federal lines. It looks like too many parts of the system are broken to ensure safe access to a basic need. You can't trust local government or companies, you can't trust the state health dept to do its job and the EPA is just fine with letting you drink poisoned water for months if not years
Kinda makes me want to get my own water tested...
http://www.nytimes.com/2016/01/28/nyregion/new-york-testing-water-in-hoosick-falls-for-toxic-chemical.html
http://www.nytimes.com/2016/03/14/nyregion/pollutant-is-removed-from-water-in-hoosick-falls-ny-cuomo-says.html
https://www.epa.gov/sites/production/files/2015-12/documents/hoosickfallsmayorpfoa.pdf
According to a timeline of events posted on the villages website, the concerns about the water supply in Hoosick Falls first came to local officials attention in August 2014, when a resident requested that leaders test the water supply for PFOA.
The State Health Department told village officials that testing would not be necessary. After public pressure, local officials decided to test the water for PFOA anyway, finding that some of the villages municipal wells contained water with dangerous levels of the compound.
They identified the likely source of the chemical as a local plant operated by Saint-Gobain, a French company which manufactures Teflon-coated material. Yet even as worry grew in Hoosick Falls, the Health Department told local officials last January that the amount of PFOA that had been found in the water supply does not constitute an immediate health hazard, though it recognized a need to take measures to reduce it.
Testing of wells near the plant in the summer and fall of 2015 showed more troubling signs, including a sample at 45 times the recommended short-term exposure.
a public warning from the E.P.A. in mid-December
