More Problems with NERO and TDK 24x
BlakkIce
1,073
hey heres my prob first off i have teh tdk 24x with the updated bios running at pio4 i dont know why but my board chose it anywho when writing multiple copies lets say 10 the first one comes out fine at 24x but when i put the 2nd cd to burn in there the drive its self starts reving upp it slows down when it starts writing but not enough and i get a track following error which in case means the drive vibrates too much anyone else having this prob
GoldenGuppy
3,494
<< i put the 2nd cd to burn in there the drive its self starts reving upp it slows down when it starts writing but not enough and i get a track following error which in case means the drive vibrates too much anyone else having this prob >>
Is this on an Ultra ATA chain?
Sounds like a physical problem... how is your TDK secured? My cousins have the exact same drive and it doesn't vibrate much at all..
Try putting it on a 33 chain, and it doesn't need pio4
good luck
><GG>
BlakkIce
1,073
its on the primary on board controller on the same chain as my zip maybe ill try butting all 4 screws ini have 2 in
