ThetaSigma
I've recently come into a predicament, I built a budget gaming PC and got a used GTX 570 (1.2GB) for really cheap, and so far, it's been powerful enough for my taste without breaking the wallet. Now a week or two ago I found and bought another GTX 570 ("broken" but works fine) for $40 off of eBay; however, the problem is that the second GTX 570 is a 2.5GB model.
I've had no problems so far with either card, and I have managed to "hack" SLI onto my motherboard via DifferentSLI, with this, I have two 1.2GB GTX 570s working together perfectly. On the one hand, more power, on the other hand, I remove the smaller (1.2GB) card and keep the bigger VRAM one. (For those that don't know, SLI-ing a big card with a little one limits it to the smallest)
I've tested with Valley Benchmark and found that on higher resolutions, the two working together is far superior, but with the game Shadow of Mordor on max the 2.5GB GTX is far superior by itself.
My question is this; what should I do? Remove the smaller card and sell it, or keep them both (while sucking up major power from my PSU)?
Details: 1680 by 1050 monitor, and an AMD 6200FX (<-- can't remember exact processor, but close enough).
