Originally posted by: ActuaryTm
Given event A being this thread proving successful and popular, it can also be said:
P(A) = 0
P(A) = 0
Originally posted by: silverpig
I don't think people are getting it.
There are an infinite number of rationals between 0 and 10 people. DrPizza is saying that your chances of picking any of those infinite number of points is zero. He's not saying to pick one (say 3/4) and asking what your chances of picking that number are. It's actually quite a big statement. 🙂
:Q
I'm just making sure I get this when I say what's below:
For all rational numbers between 0 and 1:
Say you take 1/x as your first rational number, where x = 1. Then you do this for x =2, 3, 4, "going on forever." And that's just a small set of all numbers between 1 and 0. So you can basically create an infinite amount of rational numbers just between 0 and 1.
Then you do the same concept for every number between 1 and 2, and so on.
Since there's an infinite number of rationals, the probability of picking any single rational number out of what is effectively an "infinite" amount of numbers, the probability is 0.
Is that a correct way of thinking about it?
P(A) = 0
Hey, since so many people in the .999... thread couldn't comprehend infinity, I figured I'd toss in that there are different sizes of infinity.
Originally posted by: Kibbo
Hold, on, wouldn't the probablity of that just be the total number of numbers in the set(infinity) divided by the number rational numbers in the set (infinity), which means that the answer isn't 0, the answer is meaningless.
If a number between 0 and 10 is chosen completely randomly, with all numbers having an equal probability of being selected, well, then, the probability of selecting a rational number is Zero!
Originally posted by: JohnCU
how?
because there is an infinite amount of irrational numbers between 0 and 10?
Originally posted by: Heisenberg
Saturday + math = teh noes
