- Jan 4, 2001
- 41,596
- 20
- 81
As I mentioned in a thread long ago, I intended to set up a little woodworking shop in one of the rooms of my apartment. The problem is, every single device wants a ground connection, which I wasn't expecting. Why is it a problem? There's only one grounded outlet in the room, and it won't support the current draw of what I need to run.
I've got a big vacuum cleaner, which, according to my Kill-A-Watt, draws 7.9A when running. (The KAW beeped when the vacuum started up, indicating a momentary draw >15A. :Q)
The wiring to the grounded outlet is 12/2, to a 20A breaker, and was just installed in September 2007.
Anyhow, with 8A devoted to the vacuum, that doesn't leave a whole lot to run power tools. The bandsaw alone is rated 8.8A, and likely will draw more than that, especially when it's trying to cut something.
Ideally I'd like to have the vacuum running anytime another device is being operated. Another note, the vacuum's hoses are dryer hose, which will either be entirely aluminum or old vinyl with a steel wire inside, so the hoses themselves will be connected to the vacuum's ground.
The other issue is, in the summer, the grounded outlet will be used to run a 6000BTU air conditioner.
So the question is, which is better, if either:
1) Keep the vacuum grounded, but let everything else run ungrounded.
2) Run everything ungrounded. (except the AC)
The floor is carpeted, covered with plastic, with waferboard on top of that, so it's not like I'd be standing on a wet concrete floor.
People survived use of electrical devices before ground connections were mandatory.
I have read that running one ground wire to multiple circuits is a bad idea, as the electricity can find some odd paths in some cases. That's why I'm wondering about option 1 - if one device is grounded, and it makes contact with something else, it might set up one of those funky ground circuit. I don't want to be vacuuming up the floor, holding the grounded hose, then touch the lathe and become a ground conductor.
Getting an electrician in isn't an option right now. My landlord spent $500 shortly after I moved in to get new circuits put in at my request (nothing was grounded before). I don't think I can ask him again to do something like that - I'd have to pay for the new work I'd want done.
 Facebook
Facebook Twitter
Twitter
