More chkdsk problems
Zoinks
826
After having chkdsk screw up several files by setting their size to 0, I tried running it under the windows xp command prompt and got the following:
CHKDSK is verifying files (stage 1 of 3)...
File verification completed.
CHKDSK is verifying indexes (stage 2 of 3)...
Index verification completed.
CHKDSK is verifying security descriptors (stage 3 of 3)...
Security descriptor verification completed.
CHKDSK discovered free space marked as allocated in the volume bitmap.
Windows found problems with the file system.
Run CHKDSK with the /F (fix) option to correct these.
I reran chkdsk with /f and rebooted. While booting chkdsk reported no errors. However, after booting I get the same errors. How can I fix them? Is there another program that works any better? Norton used to have something but now it think it only runs chkdsk.
toant103
10,514
toant103
10,514
toant103
10,514
toant103
10,514
sorry, i was trying to ident by hitting enter, but didn't do what i wanted.
maybe the hard disk is bad
Nothinman
30,672
You will always get minor inconsistencies if you run chkdsk on a volume mounted read-write becaue the OS's filesystem cache might not be in sync with what's on disk.
Nothinman
30,672
Not as long as the OS is running, the only time it's 100% guaranteed to be in sync is when the volume isn't mounted read-write.
Nothinman
30,672
Why? Anything that runs has to run from inside the OS, and if you're checking the system drive the OS has to be running so you'll get the same results.
