Okay peeps, I need your help on this one. I can get the motherboard to power up and go. the ONLY time it has trouble is when I either change some settings in the BIOS, or I reboot the system. Otherwise everything is fine. I have tried taking out the jumper that makes the voltage for the CPU 2.5. I have a 400 watt power supply. I'm currently running the athlon thunderbird 1.2ghz, not overclocked or anything. I also have the netgear FA311, i hear that there are some compatibility problems with the two??
