Originally posted by: n7
Tru.dat
same here...best screen cleaner out there & only Monster product worth buying![]()
Originally posted by: Cheex
On CRTs...Windex FTW!!
Not a good idea. It contains ammonia and will often remove the anti-reflective coatings that are used on many CRTs.
Originally posted by: j0j081
Klear Screen is much better. It's what the pros use.
Originally posted by: firewolfsm
A wet towel gets the job done just as well.
Originally posted by: Jschmuck2
Yep that's the stuff.
Edit:Not a good idea. It contains ammonia and will often remove the anti-reflective coatings that are used on many CRTs.
yep ammonia on a crt/lcd = bad
Strips the anti-glare coating over time.
when I was with GE we had what we called "windex syndrome"
It was from people that would spray windex on the tv screen and it would run down the front of the crt.
It would drip behind the gap between the bottom of the crt and the plastic case , onto the buttons below.
Over time it shorts them out.
Myself I use dryer sheets on my crt/laptop. Cleans well, leaves a slightly anti-static coating and smells "springtime fresh"
Old thread but your post caught my eye since it's been bumped up.
I know about the glass cleaner syndrome as well as how it can strip the coating off of a screen over time. Not a good thing if you plan to keep your monitor long. But for general consumers, it's convenient to use.
The question I would have for you is about the dryer sheets. Aren't the sheets somewhat abrasive? I figure this would be bad for screens as well. If you have an expensive monitor you'd probably want to use something softer that hopefully also leaves no lint or streaks.
Personally, I use soft tissue (the kind for camera lenses) or microfiber cloth and alcohol. Prefer denatured alcohol which I always keep a bottle of.
