A friend of mine can possibly get me these for cheaper than the advertised $70. Has anyone used these for the 360? How much of a difference do they make. BTW I have a hi-def tv too.
With my past experience with Monster cables, they are typically only worth it if you have a very high-end HDTV. Although, many people here will say they aren't worth the price premium, but depending on the price break you're getting, they may change their mind. Just make sure not to buy these cables, then plug them into a crap component switcher, because you'd be defeating the whole purpose.
About half off. No component switcher, just 360 to tv(well audio to the reciever). Now the tv isn't that high end, but it is a mitsubishi 42" HD. Thanks for the input
Originally posted by: DaveSimmons
Monster cables are usually a step up from the absolute cheapest cables you can buy, but are priced 2-4 times what they are worth.
So if by "cheaper" you mean $50 then it's still a rip-off. At $20-25 it's an OK deal.
