Originally posted by: alkemyst
I hunt down closeouts online....I don't have to have all matching cables so I just look for deals.
I bought some nice $75 rca's for my car by StreetWires (musica series) and they were getting sold at $14 each shipped.
Å
Originally posted by: glen
I have well over $10,000 in speakers alone.
Let me assure you copper wire is copper wire.
There are only so many mines, and so many extrusion facilities.
They are all they same except for the jacket.
That is right - the copper wire in all the different brands of audiophool wire is extruded from the same exact plant.
Some wire companies add in resistors, which makes short runs sound liek long runs of wire.
What matters marketing.
NO ONE HAS EVER DISTINGUISHED BETWEEN ELECTRICAL LAMP CORD WIRE CUT FROM A 20 YEAR OLD LAMP, AND UBER EXPENSIVE CABLES IN ANY ABX TEST DONE.
ahem. Some speakers are more susceptible to wire than others. Particularily electrostats where it has been proven that you get high frequency rolloff on the order of 2-3 dbs with certain cable.
That will cause a 2 to 3db roll off on the highs (duh) They have built a wire with resistors, so it is by definition a fvcking crossover. And by definition makign the sound worse.Some wire companies add in resistors, which makes short runs sound liek long runs of wire.
Originally posted by: se7enty7
I'm so sick of hearing this. SEARCH SEARCH SEARCH. Of all the topics that have been discussed once every three days, THIS is the one.
do a simple search for
"cable"
and there are 8 topics similar to this one.
To save you the trouble;
buy Acoustic Research
Well yes and no....depends if you have noise sources near by. Tests with noise sources definitely prove wires can make a difference.
Å
"cable"
No, the conclusion is buy cheap crap from home depot. Obviously you have either not searched or not read my extensive testing and supporting data.
"cable"
"cable"
I have searched, and does your data take into consideration the difference between analog and digital??
If you search you will find that while the actual CABLE might be the same, AR gets you better connectors. So while your cable might be the same now, what about in 8 months? Feel like dragging your tv out and jiggling the interconnects?
"There goes your daaata, out the window.." (to the tune of that doggie in the window)
