Monitoring temps while testing an OC
bradyapba
240
I have a question...i want to add a NV5 to my 6800gt, and i want to be able ot compare temps before and after..while under load...
how do some of you run the temp monitor and whatever load program at the same time where you can see the load temps??
thanks for any help.
Chris
bradyapba
240
yes, i have seen it, but im curious as how do you watch it/record it which putting the GPU under load? i cant seem to figure how to push the GPU while monitoring the temps at the same time, so i can see what temps the GPU is at while its under load.
Navid
5,053
It shows a log of temperatures on a window that you can open. You can also have it store the log into a text file.
