Monitor won't power off as set.
rivan
9,677
My monitor won't power off consistently. It's an ingoing issue, and has lived through more than one complete format & reinstall, and more recently a motherboard/CPU swap, and now a new monitor. I ended up with a burn in my old monitor, and would love to avoid burning into this one too.
It cropped up sometime after I switched to LCD from CRT, but I'm not sure it's related to that - it didn't happen immediately with the switch.
Neither Google searches nor searches here have turned anything up. Help, please!
Here are my machine specs (everything's at stock speeds), a cpu-z dump and hijackthis log:
E6300
ECS P4M800PRO-M
2x1gb ram
AGP x850xtpe
acer 2216W (previously a Princeton 19" LCD)
WinXP
CPU-Z
Number of processors 1
Number of cores 2 per processor
Number of threads 2 (max 2) per processor
Name Intel Core 2 Duo E6300
Code Name Conroe
Specification Intel(R) Core(TM)2 CPU 6300 @ 1.86GHz
Package Socket 775 LGA
Family/Model/Stepping 6.F.6
Extended Family/Model 6.F
Core Stepping B2
Technology 65 nm
Core Speed 1863.1 MHz
Multiplier x Bus speed 7.0 x 266.2 MHz
Rated Bus speed 1064.6 MHz
Stock frequency 1866 MHz
Instruction sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T
L1 Data cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 2048 KBytes, 8-way set associative, 64-byte line size
Chipset & Memory
Northbridge VIA P4M800CE rev. 00
Southbridge VIA VT8237 rev. 00
Graphic Interface AGP
AGP Revision 3.0
AGP Transfer Rate 8x
AGP Side Band Addressing supported, enabled
Memory Type DDR2
Memory Size 2048 MBytes
Memory Frequency 266.2 MHz (1:1)
DRAM Interleave 2-way
CAS# Latency (tCL) 3.0 clocks
RAS# to CAS# (tRDC) 4 clocks
RAS# Precharge (tRP) 4 clocks
Cycle Time (tRAS) 10 clocks
Command Rate 2T
System
System Manufacturer ECS
System Name P4M800PRO-M
System S/N 00000000
Mainboard Vendor ECS
Mainboard Model P4M800PRO-M
BIOS Vendor American Megatrends Inc.
BIOS Version 080012
BIOS Date 07/19/2006
Memory SPD
Module 1 DDR2, PC2-6400 (400 MHz), 1024 MBytes, OCZ
Module 2 DDR2, PC2-6400 (400 MHz), 1024 MBytes, OCZ
Software
Windows Version Microsoft Windows XP Professional Service Pack 2 (Build 2600)
DirectX Version 9.0c
Hijackthis
Logfile of Trend Micro HijackThis v2.0.0 (BETA)
Scan saved at 1:23:11 PM, on 9/2/2007
Platform: Windows XP SP2 (WinNT 5.01.2600)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\System32\Ati2evxx.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\WINDOWS\system32\Ati2evxx.exe
C:\WINDOWS\system32\spoolsv.exe
C:\Program Files\Alcohol Soft\Alcohol 120\StarWind\StarWindService.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\VIA\RAID\raid_tool.exe
C:\WINDOWS\SOUNDMAN.EXE
C:\Program Files\Microsoft IntelliPoint\ipoint.exe
D:\Program Files\Adobe\Acrobat 8.0\Acrobat\Acrotray.exe
C:\WINDOWS\system32\ctfmon.exe
C:\Program Files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe
C:\Program Files\Mozilla Firefox\firefox.exe
C:\WINDOWS\system32\rundll32.exe
C:\WINDOWS\System32\ssflwbox.scr
C:\Documents and Settings\Double\Desktop\HiJackThis_v2.exe
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = *.local
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
O2 - BHO: Adobe PDF Conversion Toolbar Helper - {AE7CD045-E861-484f-8273-0445EE161910} - D:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll
O3 - Toolbar: Adobe PDF - {47833539-D0C5-4125-9FA8-0819E2EAAC93} - D:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll
O4 - HKLM\..\Run: [RaidTool] C:\Program Files\VIA\RAID\raid_tool.exe
O4 - HKLM\..\Run: [SoundMan] SOUNDMAN.EXE
O4 - HKLM\..\Run: [IntelliPoint] "c:\Program Files\Microsoft IntelliPoint\ipoint.exe"
O4 - HKLM\..\Run: [Acrobat Assistant 8.0] "D:\Program Files\Adobe\Acrobat 8.0\Acrobat\Acrotray.exe"
O4 - HKLM\..\Run: [Picasa Media Detector] C:\Program Files\Picasa2\PicasaMediaDetector.exe
O4 - HKCU\..\Run: [ctfmon.exe] C:\WINDOWS\system32\ctfmon.exe
O4 - Startup: World Community Grid Agent.lnk = C:\Program Files\WorldCommunityGrid\UD.EXE
O4 - Global Startup: Adobe Acrobat Speed Launcher.lnk = ?
O4 - Global Startup: Adobe Acrobat Synchronizer.lnk = D:\Program Files\Adobe\Acrobat 8.0\Acrobat\AdobeCollabSync.exe
O8 - Extra context menu item: Append to existing PDF - res://D:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
O8 - Extra context menu item: Convert link target to Adobe PDF - res://D:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
O8 - Extra context menu item: Convert link target to existing PDF - res://D:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
O8 - Extra context menu item: Convert selected links to Adobe PDF - res://D:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIECaptureSelLinks.html
O8 - Extra context menu item: Convert selected links to existing PDF - res://D:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIEAppendSelLinks.html
O8 - Extra context menu item: Convert selection to Adobe PDF - res://D:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
O8 - Extra context menu item: Convert selection to existing PDF - res://D:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
O8 - Extra context menu item: Convert to Adobe PDF - res://D:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - %windir%\Network Diagnostic\xpnetdiag.exe (file missing)
O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - %windir%\Network Diagnostic\xpnetdiag.exe (file missing)
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O16 - DPF: {0A5FD7C5-A45C-49FC-ADB5-9952547D5715} (Creative Software AutoUpdate) - http://www.creative.com/su/ocx/15030/CTSUEng.cab
O16 - DPF: {17492023-C23A-453E-A040-C7C580BBF700} (Windows Genuine Advantage Validation Tool) - http://go.microsoft.com/fwlink/?linkid=39204
O16 - DPF: {F6ACF75C-C32C-447B-9BEF-46B766368D29} (Creative Software AutoUpdate Support Package) - http://www.creative.com/su/ocx/15030/CTPID.cab
O22 - SharedTaskScheduler: Browseui preloader - {438755C2-A8BA-11D1-B96B-00A0C90312E1} - C:\WINDOWS\System32\browseui.dll
O22 - SharedTaskScheduler: Component Categories cache daemon - {8C7461EF-2B13-11d2-BE35-3078302C2030} - C:\WINDOWS\System32\browseui.dll
O23 - Service: Ati HotKey Poller - ATI Technologies Inc. - C:\WINDOWS\System32\Ati2evxx.exe
O23 - Service: ATI Smart - Unknown owner - C:\WINDOWS\system32\ati2sgag.exe
O23 - Service: FLEXnet Licensing Service - Macrovision Europe Ltd. - C:\Program Files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe
O23 - Service: Google Updater Service (gusvc) - Google - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe
O23 - Service: StarWind iSCSI Service (StarWindService) - Rocket Division Software - C:\Program Files\Alcohol Soft\Alcohol 120\StarWind\StarWindService.exe
End of file - 5940 bytes
rivan
9,677
I'd even be happy with a link to somewhere better to ask!
KAZANI
527
-Have you examined whether it doesn't go into power save mode at all or it does, but turns on at some point later? Disable any screensavers and set the monitor off timing to minimum for testing.
-Confirm that your hardware drivers and operating system are up to date.
-Try disabling start up programs, especially automatic updaters and see if that solves the issue.
