I've got a problem with my monitor - Dell 2408WFP. I've had it about 2.5 years now.
This has just started happening in the last month or so.
It's a little hard to describe, but I can't seem to add attachments, so I don't know how to upload a screenie...
Anyway, on my black desktop background, to the right of every icon, and about the same width and height as the icons, are a bunch or red pixels, with the farthest right edge "shimmering" a bit. I guess it's like as if every icon is casting a red pixel shadow.
It's there in other applications too, Lightroom, AE, VLC...
I've reset the monitor, etc. but to no avail.
I'm running through DVI from a Radeon 4890, but I've unplugged the cable and the problem remains on he OSD, so it looks like it's 100% a monitor problem.
The pixels will change around, too...It's not as if they're stuck or permanently like that.
And it does fix itself too, but right now it's been like this for a few hours, the longest I've seen. Restarting the computer, powering off and on the monitor...nothing changes. When it does change back to normal it seems to just do it on its own.
I hope the monitor isn't dying...it cost a bit...
Cheers
Cheers
